Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 10-10-2007, 03:08 PM   #1
water heater
My water heater has a tiny leak in the bottom. Just a couple of drops at a time.Does this mean I need a new one?
If I need a new one what is a good one to get?
jerry1967 is offline   Reply With Quote
Old 10-10-2007, 09:27 PM   #2
water heater
I think odds are very high the problem is to fetch yourself about a $3 new gasket from a hardware-type store..THEN turn breaker to hotwater "OFF",let it cool a good couple hours B4 even contemplating(scalding issues) taking out element(s)..better yet see if re-tightening them as they are a bit more to see if it stops.
Dyn'R is offline   Reply With Quote
Old 10-10-2007, 10:18 PM   #3
water heater
Can you send me a picture where to look for this leak, and where this gasket would be located?
Old 10-10-2007, 10:27 PM   #4
water heater
Jerry,
Is this a Electric hot water tank OR a propane heated,leaky beast? I'll go snap a rather crapy pic(sorry camera is quite the crapper)..should be posted.. say 20mins-ish!
Old 10-10-2007, 10:45 PM   #5
water heater
After side cover is removed.
Old 10-11-2007, 08:18 AM   #6
water heater
It is nature gas!.
The leak looks like it is coming from the bottom. If it is this gasket could the water be flowiing to the weak spot in the bottom then coming out?
Can I take the cover off the inspect it without turning the breaker off first?
Old 10-11-2007, 09:13 AM   #7
water heater
you don't have that cover on your propane unit.
Check the top of the heater, to see if there are any leaks at the connections going into the tank.
Check the drain valve area at the bottom to see if that's leaking.
Otherwise, I think the chances are that you need a new water heater. How old is this one?
NateHanson is offline   Reply With Quote
Old 10-11-2007, 09:27 AM   #8
water heater
You need to determine where the leak really is. Throroughly wipe walls, top, especially around connections. Wipe around drain valve. Then, see if water might be originating there. If it really seeps from under the bottom, you better replace it soon.
scorrpio is offline   Reply With Quote
Old 10-11-2007, 11:04 AM   #9
water heater
The connection for the hot water going into the tank is all rusty; it has been for some time. Could this be leaking down the inside of the tank coming out the bottom? If this is leaking can this be fix with new connections?
Old 10-11-2007, 01:42 PM   #10
water heater
Forget everything i said,I've never messed with a propane heater.
Old 10-11-2007, 02:50 PM   #11
water heater
How old is the tank?
redline is offline   Reply With Quote
Old 10-11-2007, 03:37 PM   #12
water heater
I am not sure but I think 8 years.
Old 10-11-2007, 07:06 PM   #13
water heater
Hi jerry
I have not had a propane hot water tank, but my last home had natural gas, so I expect it would be very much similar. I lived there for 23 years. I replaced the original tank after about seven years in the house. That one lasted about seven or eight years. I replaced it when it started to leak. That tank went in 2005, but by that time we had sold the place to a developer, and we were living there as renters. The landlord got to replace that one. There are some perks to being a renter. We moved this year, and bought a place in another city. The best conclusion that I can make from my experience with hot water tanks, is that if it is eight years old, and starts to leak, shut the heat off, close the taps, and buy a new one.
PS: The place that I had before also had a gas hot water tank, and when it leaked, I tried to repair it. That was an utter waste of time.
Good luck
Gerry
Gerry Kiernan is offline   Reply With Quote
Old 10-12-2007, 01:30 AM   #14
Long-Time DIYer
Mike Swearingen's Avatar
water heater
Basically, you can repair/replace almost everything on a water heater EXCEPT the tank. Once the tank starts leaking, it is best to replace the heater asap, or the tank could burst and flood your home.
If you're not familiar with working with gas lines, hire a pro plumber.
Good luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 10-12-2007, 08:13 AM   #15
water heater
Ok I quess I am going to replace it-what kind should I buy and where whould I buy it?
Electric Water Heater GTSRider Plumbing 31 12-07-2008 12:30 PM
No Expansion Tank for Water Heater vasanvasan Plumbing 4 12-14-2007 12:16 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 04:53 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 07:01 PM
