Water In Door Does Not Work - Appliances - DIY Chatroom Home Improvement Forum
Old 11-26-2010, 02:25 PM   #1
water in door does not work
how do we fix water not working to door of fridge.
bmeredith1 is offline   Reply With Quote
Old 11-26-2010, 03:16 PM   #2
the Musigician
DangerMouse's Avatar
start at the beginning and when you get to the end, stop.
DM
Old 11-26-2010, 06:35 PM   #3
Rewards Points: 468
Not much info. But i guess the valve under the sink if that is where it is. Or find it loosen up the fitting get water? go to the next fitting if on the back of frig. Check and see if frig was moved out and pushed and pinch the line?? Keep checking tell you find water?
del schisler is offline   Reply With Quote
Old 11-26-2010, 06:38 PM   #4
the Musigician
that's what I said....
DM
Old 11-26-2010, 06:40 PM   #5
Rewards Points: 468
DM
not steping on your toes. But i guess maybe he need to here it again
Old 11-26-2010, 06:43 PM   #6
the Musigician
Perhaps my Mad Hatter analysis is vague, but so was the question.
DM
Old 11-26-2010, 06:46 PM   #7
Rewards Points: 468
DM
It is dam hard to see it from here also. Some post's sure are pulling info from . Dam i know that someone out their know's ??? crystal ball isn't working
Old 11-26-2010, 11:03 PM   #8
Rewards Points: 150
Does your fridge door have the cold water dispenser type? Is this what your saying? Did you put water in the dispenser found inside the door? Or there might be something hindering the flow of water from the dispenser to the faucet. Check that also.
MagicalHome is offline   Reply With Quote
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 03:20 PM
My hot water recirculation system is a disaster Michael Neill Plumbing 9 11-05-2010 12:31 PM
recent basement work and discolored water downers Plumbing 2 04-10-2009 06:30 PM
Low Hot Water Pressure btennant Plumbing 4 12-09-2008 10:31 PM
Hot Water Baseboard does not work iwolff Plumbing 6 02-14-2008 07:19 AM
