-   -   water in door does not work (http://www.diychatroom.com/f47/water-door-does-not-work-87788/)
bmeredith1 11-26-2010 02:25 PM
how do we fix water not working to door of fridge.
DangerMouse 11-26-2010 03:16 PM
start at the beginning and when you get to the end, stop.
DM
del schisler 11-26-2010 06:35 PM
Not much info. But i guess the valve under the sink if that is where it is. Or find it loosen up the fitting get water? go to the next fitting if on the back of frig. Check and see if frig was moved out and pushed and pinch the line?? Keep checking tell you find water?
DangerMouse 11-26-2010 06:38 PM
that's what I said....
DM
del schisler 11-26-2010 06:40 PM
DM
not steping on your toes. But i guess maybe he need to here it again
DangerMouse 11-26-2010 06:43 PM
Perhaps my Mad Hatter analysis is vague, but so was the question.
DM
del schisler 11-26-2010 06:46 PM
DM
It is dam hard to see it from here also. Some post's sure are pulling info from . Dam i know that someone out their know's ??? crystal ball isn't working
MagicalHome 11-26-2010 11:03 PM
Does your fridge door have the cold water dispenser type? Is this what your saying? Did you put water in the dispenser found inside the door? Or there might be something hindering the flow of water from the dispenser to the faucet. Check that also.
