Water Dispenser Stopped Working - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 05-07-2011, 11:57 PM   #16
I am having the same problem with GSH25KGPA FRIDGE
previous homeowners left this fridge so I dont know the history.
I changed the filter 2 weeks ago. The water worked fine for a while, then just stopped. Icemaker is working fine.
The solenoids are ok. I disconnected tubing coupling located front left bottom. This is where the supply line enters the freezer door. Water comes out there when the lever is activated. But when I reconnect, no water.
I tried to blow up the line but it was blocked.
seems like a valve of some sort isnt opening.
The instruction manual says
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds
will try next time i am at the house and reply back.
Wouldn't that be something if that is all it was.
jakerot is offline   Reply With Quote
Old 05-15-2011, 11:50 PM   #17
I am having the exact same issue, a couple of weeks ago my water stopped working. I purchased this fridge new about 7 yrs ago. I know water is getting to the line that enters the freezer door but it won't dispense. I went as far as to snake the line to see if I could clear the blockage but to no avail. It seems that whatever is blocking the water from dispensing is located about 2 inches back from the dispenser nozzle. Any ideas?
CJH98 is offline   Reply With Quote
Old 05-16-2011, 12:48 AM   #18
I am starting to think the line in the freezer door is frozen. turned setting down to 1 in the freezer section last week. still no water. the freezer is empty now however. I might pull the plug and see if that melts it.
Old 05-16-2011, 05:50 AM   #19
IF you're getting water to the door and you hear the solenoid humming- the line inside door is frozen....IF the interior liner is metal and your serial # is between AF thru AM; you need heater kit # wr49x10173....it's a little tricky to install and you only get one shot to screw it up, so unless you're hard core, call someone to install it.
Jacques is offline   Reply With Quote
Old 05-16-2011, 11:17 AM   #20
Household Handyman
Rewards Points: 1,408
When you attempt to get chilled water you are activating a switch which tells the solenoid valve for this line to open and dispense water. You may hear a "click" noise and a "hum" as if the solenoid is working. This does not mean that the solenoid is indeed opening the small needle valve to allow water to pass through. I have seen these valves get stuck and not open even though the solenoid checks out just fine. If you feel "Handy-Dandy" then try this: Find out which solenoid is for the water dispenser, remove the water line which feeds your dispenser, have someone attempt to obtain water from the dispenser, BUT only for a second. IF no water comes out of the valve--you need a new valve. IF it does, sorry, clean up the mess and continue to troubleshoot the rest of this system.
Old 05-16-2011, 05:48 PM   #21
Like Jakrot I have uncoupled the line in the front left beneath the fridge and water dispenses when the switch is tripped. I need to know what is behind the external water spout as that seems to be where it is blocked.
Ice maker stopped working bragl01 Appliances 5 10-30-2015 06:56 AM
Frigidaire water dispenser does not work waywestside Appliances 4 09-27-2011 02:20 PM
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 01:35 PM
Frigidaire fridge water dispenser won't stop nonanon Appliances 1 10-05-2007 08:16 PM
Main valve not working. Water won't turn on! skellies Plumbing 1 10-31-2006 02:17 AM
