-   -   Water Dispenser Stopped Working (http://www.diychatroom.com/f47/water-dispenser-stopped-working-17842/)
dgoldb1 02-29-2008 05:21 PM
I have a GE fridge (4 years old) and the water dispenser has stopped working. The ice maker works just fine. When I try to use the water I hear a pump running, just no water comes out. Any ideas what may cause this behavior?
Thanks.
Wood Butcher 02-29-2008 05:44 PM
do you have a lot of sediment in your water? you could have a blockage of some kind. if ice maker works you are getting water, and you said you can hear the pump running, so it sounds like you are not getting water into or out of the pump
dgoldb1 02-29-2008 05:47 PM
I have city water so I couldn't imagine there being much sediment in the water.
MinConst 02-29-2008 06:24 PM
If you ice maker is truly getting water then there must be a blockage to the water outlet. Be sure the ice maker is really getting water and if so take the thing apart and find the blockage.
terri_and_jj 02-29-2008 06:47 PM
if your ice maker isn't getting water could be your filter is clogged. i agree it's got to be blockage if everything in your posting is accurate
dgoldb1 02-29-2008 06:51 PM
I have emptied the entire ice maker and the next day it was full so I am pretty sure that the ice maker is getting water.
terri_and_jj 02-29-2008 07:17 PM
then i would take a look at where water lines connect to and from the pump
End Grain 02-29-2008 07:45 PM
Your fridge may have a built-in sensor that cuts out the water dispenser feature when the filter is getting or actually clogged as a reminder. One of my customers has such a fridge. State-of-the-art electronic wonder. If you have another filter or if one is inexpensive enough to buy and try, see if changing it will do the trick.
LawnGuyLandSparky 03-01-2008 08:02 AM
The water dispenser is a CHILLED water dispenser. It chills by running the water dispenser supply line either through a hunk of coiled water line or through a small container inside the refrigerator usually behind the bottom vegetable crisper. See if it's frozen and if it is, your fridge temp is too low.
dgoldb1 03-01-2008 09:41 AM
Doesn't the ice maker get water through the filter as well as the water dispenser? I tried turning the temp to the warmest settings for a couple day because I thought the lines may have frozen. No luck...I didn't check behind the vegetable crisper. I'll have to take a look there.
End Grain 03-01-2008 11:15 AM
Yes , but this feature on the fridge I'm referring to was probably put in there as a way of reminding the consumer that the filter has to be changed. Ice cubes are out of sight and out of mind at least until the supply runs out but filtered water is a go-to thing numerous times a day.
In this customer's case, the replacement filter's instructions stated it had to filled with water and dumped out several times, then refilled again, allowed to sit for a couple of minutes and installed so that the sensor would detect the flow. Best part was that the filter cost $38!!!
I'm only suggesting that before you go and dismantle things or get too far along in your diagnostics, try the simplest stuff first. Do you have the owner's manual? If not, you can probably go up on-line and look at it at the manufacturer's site.
girltech 03-03-2008 02:58 PM
Can you supply the model number of your fridge?
The fridge does not have a water pump it has solenoid valves.
There is a separate valve for the ice maker and the water dispenser.
They are located at the back of the fridge where the water line hooks on.
You can check them with a meter.
dgoldb1 03-03-2008 05:41 PM
The fridge is a GE model GSH25KGPA.
I was reading online somewhere about exactly what you mentioned. There is a dual solenoid, one fore the ice maker and one for the water dispenser.
Now the odd thing is that I hear something trigger when I try to get water... out
girltech 03-04-2008 12:34 PM
Now that I have your model number I can see that your fridge has an electronic control.
Is there anything strange happening when you request water like the fan slowing down or the lights dimming?
You may be hearing a relay on the board.
Here is a good place to look at the breakdown of your appliance parts.
dgoldb1 03-04-2008 02:13 PM
I hear a click and then a hum when I try to get water out. I wonder if I need this part...
http://www.partselect.com/xq/aspx/In...lNum=GSH25KGPA
