Water Dispenser - Appliances - DIY Chatroom Home Improvement Forum
Old 09-09-2011, 06:58 PM   #1
water dispenser
The water dispenser on my side by side frigidaire works but only after I undo the filter cover and dump out the water .The cover is replaced and the water dispenser works the ice maker works but not the water .The solinoid valve has been replaced and also the feed hose from the water main to the valve .There is 70 pounds of pressure before and after the valve.What I don't understand is why it won't dispense water until the filter cover is removed we can fill up a large pitcher but upon relase of the switch no more water.The model number of this unit is FRS24ZGG Lines are not frozen or there would be no water.
woodbits is offline   Reply With Quote
New hookup water and ice dispenser not working billybarty Appliances 6 02-18-2011 08:34 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
Very Low Hot Water Pressure. PAS1970 General DIY Discussions 2 02-25-2009 04:01 PM
low hot water pressure angus242 Plumbing 10 01-08-2009 12:41 PM
No water to dispenser or ice maker Shannicole Appliances 5 05-12-2008 08:17 PM
