Water Coming From Bottom Of Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 12-23-2008, 05:54 PM   #1
water coming from bottom of fridge
I noticed water coming out of the bottom of my fridge, I pulled it out to look behind and noticed it is only on the freezer side, I looked inside the freezer and notice the ice maker had a solid block of ice in the compartment and a huge ice cycle going to the ice tray, where is the leak and if I shut off the ice maker by raising the arm will that stop the water from turning on to the ice maker or just stop it from dumping ice?
-J
Jshakour is offline   Reply With Quote
Old 12-23-2008, 06:09 PM   #2
*****UPDATE******
I was wiping up the water on the floor and looked at the back of the fridge, it appears that the plastic line going to the ice maker was pull out of the back of the fridge....
1.) how did it come out?
2.) if it was out, why was there an ice block in the ice tray?
-J
Old 12-23-2008, 06:10 PM   #3
to be safe trace the waterline back to where it starts out from and turn the valve off there. could be a bad heater that melts the ice so it slides off into the bin
kennzz05 is offline   Reply With Quote
Old 12-23-2008, 06:38 PM   #4
i put the arm down and watched the ice maker try to dump the ice, there was no ice in the tray probably b/c the waterline was pulled from the back, I touched the heater underneath and it was a bit more than warm.
-J
Old 12-23-2008, 07:34 PM   #5
*****UPDATE*****
I put the plastic line back into the back of the fridge and it popped back out again, could there be ice in the line and when the water hits it the force pushes it out?
-J
Old 12-23-2008, 08:17 PM   #6
http://www.applianceblog.com/mainfor...ead.php?t=1975
i found this, and this seems like my problem. So if, my water line into the freezer (from the back of the freezer in) is frozen, how do I thaw it?
-J
Old 12-24-2008, 06:36 AM   #7
Try the hairdryer
Chemist1961 is offline   Reply With Quote
Toilet: water still coming from BOTTOM of Inlet Valve DIY Mom Plumbing 1 08-12-2008 12:43 PM
Brand New Whirlpool fridge - Water dispenser stopped working!! jpherron Appliances 2 01-04-2008 01:35 PM
No Water Flowing To Fridge garyb123 General DIY Discussions 5 12-24-2007 12:28 AM
how to run fridge water line under kitchen floor? travishume Plumbing 23 09-26-2006 07:51 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
