Water Coming From Bottom Of Admiral Side By Side - Appliances - DIY Chatroom Home Improvement Forum
Old 11-02-2011, 02:46 PM   #1
water coming from bottom of admiral side by side
why is water coming from the bottom of my side by side-I do not have an ice maker and the tray under the fridge is dry
koskiejm is offline   Reply With Quote
Old 11-02-2011, 03:55 PM   #2
biggles's Avatar
defrost cycle might be melting ice on the freezer during defrosting..pull the veggy bins might have water there or the drip off into that dry pan are missing it.
Old 11-02-2011, 08:51 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
your drain hole is plugged and or iced over. You will need to locate your hole, thaw it out and clean it out.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Sump pit keeps filling, can't see water coming in ks-man Plumbing 30 12-31-2014 05:32 PM
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
Low hot water pressure crebive Plumbing 38 02-26-2013 12:26 AM
No hot water at any faucet, water heater working fine rivercliff Plumbing 5 10-27-2011 09:47 AM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
