Water In Bottom Of Samsung Fridge - Appliances - DIY Chatroom Home Improvement Forum
Old 05-09-2012, 07:38 PM   #1
Water in bottom of Samsung fridge
Every couple of days we have about a cup of water in the bottom of our fridge under the crisper drawers. It is a Samsung RB195 series freezer on bottom. I have read it is most likely a clogged drain line or drain cup. My question is where is the drain line located on the Samsung so i can deforst it. Also since we have a bottom freezer and everything I read talked about this issue in a top freezer, is this even our issue?
Thank you very much for the help,
Ben
Bcoleman6 is offline   Reply With Quote
Old 05-09-2012, 10:24 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
most likely not, I would suspect a small leak in the water reservoir. Located behind the crispers.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-09-2012, 10:32 PM   #3
Would the reservoir still be behind the crispers in a bottom freezer?
Old 05-09-2012, 10:35 PM   #4
I should mention it is a rb195brbb so it has an ice maker, but no water dispenser.
Old 05-09-2012, 10:48 PM   #5
#1 HAWKEYE FAN
ok, I should have paid more attention. Samsung refrigerators use dual evaporators. So most likely you do have a plugged drain tube under your upper evap unit. remove the crispers and the shelves and you should be able to see a removable panel on the back wall. Your evap, fan motor and drain trough will be there.
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 08:44 PM
Need help figuring out walk-out basement water intrusion issue toomanypets General DIY Discussions 18 08-29-2011 08:34 PM
Leaking water line needs new water regulator? huynh Plumbing 16 11-04-2010 11:32 AM
