Water Actuator Frigidaire PLHS269ZCB3 - Appliances - DIY Chatroom Home Improvement Forum
Old 03-18-2007, 08:20 PM   #1
The water actuator broke on my fridge and was wondering how to replace it. I need to order the part and would like also to know how to gain access behind the ice/water door in order to get to the part.
Can anybody fill me in?
Thanks,
Nazz
Nazz300 is offline   Reply With Quote
Old 03-10-2008, 12:43 PM   #2
If you have not had the fridge repair yet here is how to get in to the dispenser.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts.
girltech is offline   Reply With Quote
Old 02-26-2011, 01:22 AM   #3
Sea Breeze
Techseabreeze's Avatar
Send a message via Yahoo to Techseabreeze
This is about as good of electrical diagram showing the dispenser wiring on the right side. The photo has lost some of its clarity especially in color codes. Hope this helps=> http://appliance911seabreeze.com/Fri...%20DIAGRAM.jpg
Technicianseabreeze
http://appliance911seabeeze.com/index.html
Techseabreeze is offline   Reply With Quote
Gravity Hot Water Recirculating Loop Questions harleysilo Plumbing 2 02-06-2007 03:28 PM
Water level in boiler system Barefoot Brian HVAC 3 10-19-2006 01:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
help Chuckman Off Topic 8 06-15-2006 10:06 PM
Draining a hot water heater singforsupper Plumbing 1 06-07-2006 06:01 PM
