Water Actuator Frigidaire PLHS269ZCB3
6K views 2 replies 3 participants last post by  Techseabreeze
The water actuator broke on my fridge and was wondering how to replace it. I need to order the part and would like also to know how to gain access behind the ice/water door in order to get to the part.
Can anybody fill me in?
Thanks,
Nazz
If you have not had the fridge repair yet here is how to get in to the dispenser.
Feel or look along the bottom edge of the trim on the dispenser and you will see two slots.
Use a flat blade screwdriver to pry the bottom off.
Then slide the trim up and lift it off this will give you access to the screws to replace the actuator.
Here is a place to get Frigidaire parts.
