Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-31-2011, 11:50 AM   #1
Waste water in clothes washer
Waste-water backed up into my washing machine due to a clogged sewer line in my home. Problem is now fixed but can washer be safely used? The waste water did not appear to have solids and was relatively clear. Is it sufficient to run hot water and bleach through it a few times before using it again? Thanks.
L1A2V3 is offline   Reply With Quote
Old 08-31-2011, 12:20 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
that should work just fine, hot water and bleach should kill all bacteria
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-02-2011, 04:33 PM   #3
TimAllen37's Avatar
oh my god. that sounds horrible. but yeah, hot water, bleach, etc. and you'll be fine.
TimAllen37 is offline   Reply With Quote
Old 09-02-2011, 10:52 PM   #4
Missouri Bound's Avatar
If you have water backing up into your washer it is not installed properly. Washers have an outlet hose which pumps into a stand pipe. They are not to be connected into the waste system. How is it connected that this could happen? Washers are not supplied with any backflow prevention because of their gravity / air break installation.
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
Testing 12 year old hot water expansion tank? DJfixer Plumbing 2 01-01-2009 09:09 AM
Hot water pipe making scary noises - Please help!!! Sarah24 Plumbing 4 12-16-2008 11:24 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
