Washing Machine Wont Fill With Water (Just HUMS) - Appliances - DIY Chatroom Home Improvement Forum
Old 05-13-2012, 11:32 PM   #1
Rewards Points: 12
Washing Machine Wont Fill with Water (Just HUMS)
Guys I have a Whirlpool WFW9450W Whirlpool Duet Front Loader that wont fill with water. The machine just hums and no water will enter the machine.
The water is turned on for both of the incoming supply hoses.
I changed the incoming valves part that has the valves and solenoids.
I cleaned out the motor trap underneath.
I wonder what I should try next.
Any help or direction would be appreciated.
HelpMeHvac is offline   Reply With Quote
Old 05-14-2012, 05:57 AM   #2
Flood safe fill hoses=no water?
Jacques is offline   Reply With Quote
Old 05-14-2012, 08:57 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
just hums? does the tub turn first or not. Front load machines do not fill as soon as you turn them on, they must go through a load sensing process first but you should get some type of error code in the control panel. If no error code then find the tech manual ( somewhere in machine) and do a self diagnostics test.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 05-17-2012, 09:54 AM   #4
DIY or die !
Rewards Points: 77
you should be able to run a diagnostic on those. Check it out and get back to us.
lewisthepilgrim is offline   Reply With Quote
Water heater solutions to get hot water in timely manner daluu Plumbing 22 05-07-2012 09:44 PM
A blocked water line causing water to loose heat? Snav Plumbing 6 05-07-2010 03:18 PM
Can't figure out how the "faucets" on my washing machine work zippydl Plumbing 7 08-05-2009 02:19 AM
Recycling washing machine water into grey water williamsl Green Home Improvement 1 08-03-2009 02:21 PM
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 04:36 PM
