Washing Machine Wont Fill Upwith Water - Appliances - DIY Chatroom Home Improvement Forum
Old 07-14-2012, 05:58 PM   #1
washing machine wont fill upwith water
washing machine wot fill up with water
cinlea is offline   Reply With Quote
Old 07-14-2012, 07:07 PM   #2
Rewards Points: 13,468
Sorry to hear that.
First make sure there water getting to the hose.
If there is then remove the hose and check to see if the screens pluged up inside the fitting on the end of the hose.
If there old black rubber hoses do not but them back on. Replace them with new stainless steel braded hose.
Every year hundreds of homes get flooded from old rubber hoses.
If it still does not work then someone need to check the solinoid valve to see if it's getting power. It's right behind where the hoses connect.
Old 07-14-2012, 09:17 PM   #3
Rewards Points: 83
Theres a few things it could be.
Like said already, could be water turned off. If you have those flood safe hoses the safeties could have activated locking off the hose. Solenoid valve could be stuck.
Unit could have tripped the breaker, timer assembly or pressure switch could have failed, etc. hard to tell without doing some diagnosis.
Protocol. is offline   Reply With Quote
Washine Machine wont fill with Water (Just hums) HelpMeHvac Appliances 0 05-13-2012 10:34 PM
how far can i move a washing machine from the water feed? AlKapone Appliances 26 09-26-2011 12:27 AM
Solar hot water indatom123 Green Home Improvement 0 12-19-2010 12:01 AM
New Kenmore washing machine, automatic water level question DIY DUDE Appliances 2 04-16-2010 07:52 AM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
