Sorry to hear that.
First make sure there water getting to the hose.
If there is then remove the hose and check to see if the screens pluged up inside the fitting on the end of the hose.
If there old black rubber hoses do not but them back on. Replace them with new stainless steel braded hose.
Every year hundreds of homes get flooded from old rubber hoses.
If it still does not work then someone need to check the solinoid valve to see if it's getting power. It's right behind where the hoses connect.
Like said already, could be water turned off. If you have those flood safe hoses the safeties could have activated locking off the hose. Solenoid valve could be stuck.
Unit could have tripped the breaker, timer assembly or pressure switch could have failed, etc. hard to tell without doing some diagnosis.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
