Washing Machine- Is Replacing The Tub Reasonable? - Appliances - DIY Chatroom Home Improvement Forum
Old 04-06-2009, 03:32 PM   #1
washing machine- is replacing the tub reasonable?
The bottom of the tub on my ~22 year old GE washing machine has rusted through in several holes. I don't think its patchable: 3 holes about an inch and several holes I was able to punch my awl through. All exposing the gasket sealing the flexible seal on the agitator.
Presuming I can find the tub as a replacement part, is it as simple as removing the casing and lifting the tub off of the transmission shaft? Or is the agitator shaft & seal a separate part I would have to mess with & make sure it didn't leak?
V=IR is offline   Reply With Quote
Old 04-07-2009, 04:38 PM   #2
I wouldn’t think you could get the tub and even if you can it is probably expensive. Putting it in won’t be any fun either. I personally I think its time for a new washer.
Last edited by Scuba_Dave; 09-30-2010 at 11:43 AM. Reason: removed adv link in post
applianceman is offline   Reply With Quote
Old 04-08-2009, 03:06 AM   #3
Great link.
Found out the tub isn't available anyway.
Now -- I have heard that front-load washers don't clean worth beans ???
Old 04-08-2009, 06:59 AM   #4
Rewards Points: 602
I doubt that I'll get it to last 22 years, but I've been pretty happy with my front-load washer. It seems to do a pretty good job.
gma2rjc is online now   Reply With Quote
Old 04-08-2009, 01:48 PM   #5
Front-loaders are great they are built really well and as far as I know they wash really good. Also they are easier on your clothes. The only down side is that they cost a lot and they take longer to wash. One thing some people don’t understand is that front loaders have to wash with HE detergent. Regular detergent will create soapsuds that will get in the way of the washing action of a front loader washer.
Last edited by Scuba_Dave; 09-30-2010 at 11:42 AM. Reason: removed adv link in post
Old 04-08-2009, 01:55 PM   #6
Rewards Points: 602
I was told the same thing about using HE detergent. Also that the suds from regular detergent don't wash off the back of the drum(?). They cause it to rust out quickly.
I like that mine only uses 8 gallons of water per load. Supposedly. My water bill did go down after I bought it.
Be careful though. I've read about problems with some of the brands and different models.
Old 04-17-2009, 03:17 PM   #7
We have some friends who purchased a front loader several years ago and the wife told my wife that it retains water and smells.
Preach_2 is offline   Reply With Quote
Old 04-17-2009, 08:19 PM   #8
Yes, this is one of the problems with front loaders. This website http://smellywasher.com/ sells cleaner that will solves this problem Type appliance-repair-it into the coupon box on the order form to receive a 10% discount!!
Trap and washing machine safety drain pan wildbilly Plumbing 18 03-05-2013 07:08 PM
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Cold water not working in washing machine. 68MHJCs Appliances 15 01-20-2009 05:18 AM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
