Washing Machine - Removal Of Agitator - Appliances - DIY Chatroom Home Improvement Forum
Old 03-23-2011, 03:23 AM   #1
washing machine - removal of agitator
Wanting to know how to remove the agitator from a Simpson Espirit 450 washing machine to remove a caught sash.ribbon. The older models, the agitator used to just pop out.
dexanna is offline   Reply With Quote
Old 03-24-2011, 06:41 AM   #2
Rewards Points: 152
I am not familiar with that particular one, and haven't messed with enough of them to know how common this is, but do know that some models have a small hole near the base of the agitator, through which you can insert a socket, and remove a bolt that holds the agitator in place. If this one has this bolt, and if it's like others that I have seen, you should be able to hold a mirror down there, and see the bolt head through the hole.
Old 03-24-2011, 08:51 AM   #3
If you go on UKWHITEGOODS.- they could prob tell you.
Jacques is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Lint Trap Agitator for Washing Machine? thebigsee Plumbing 2 08-16-2009 07:01 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 12:26 PM
