Washing Machine Recommendation? - Appliances - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 11:47 AM   #1
Washing machine recommendation?
Can anyone recommend a reliable washing machine with low water usage?
diyrocks is offline   Reply With Quote
Old 09-11-2012, 06:26 AM   #2
custom user
Rewards Points: 150
Take a look at the Samsung front loader. I've been very happy with mine, runs quiet and doesn't use much water. Typically, the front loaders use less water and are more efficient. The disadvantage is you can't wait too long after the start of the cycle to add stuff.
JasperST is offline   Reply With Quote
Old 09-11-2012, 09:00 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,584
top load machines are water hogs but if your going to go this way, go old school. Speed Queen
front loaders use about 65% less water than top loaders. Improvements over the last 5 years have resulted in much better machines now but they are still typically problem prone machines. Do NOT spend the extra money for the bells and whistles, it is a complete waste of money and just adds to the potential for more break downs. That being said I myself am impressed with Samsung laundry products, Whirlpools are getting better all the time. Do not like anything from Frigidaire, LG or even GE, also Kenmores unless you can verify the manufacturer.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-11-2012, 09:47 AM   #4
Rewards Points: 12,808
It just blows me away that everytime I go in HD or Lowes there's almost all ways a young couple that just built a house looking at washer and dryers.
The wife is trying to justify buying one of the $1400.00 bohemoth washing machines. One even had a phone line attached that could call for service.
All I could see was more stuff to break and money spent that could have gone toward something that would add value to the house.
My old Maytag is going on 20 years old and still has not had a single repair.
One feature I would pay a little extra for is a stainless steel drum.
Once the porcelain or enamel chips, rusting is sure to follow that will stain your clothes.
Old 09-11-2012, 09:55 AM   #5
custom user
Rewards Points: 150
That was one of the reasons I went with the Samsung set compared to others in the price range.
Old 09-11-2012, 11:50 AM   #6
Bombastic Idiot
notmrjohn's Avatar
" a phone line attached that could call for service." That's gotta tell you something about the dependability of the thing, if manufacturer thinks it needs to be that handy.
Now, if it would automatically call, without me having to even know there was sumthin wrong, that'd be worth havin. If it checked the warranty first, if it had lapsed two days ago it should call me. Better yet it should call service company just B4 lapse with some mysterious complaint that requires complete break down and rebuild just to determine cause.
First time I saw those huge glamorous high tech lookin things, I thought, "Will wonders never cease? Home Depot sells time machines now."
diyrocks, if you go over to library they have copies of Consumer Reports, they do an anual report on washers and have yearly digest of all comparisons. Not Consumer Digest, which takes ads from from products they review. Not sayin that would bias them, but if a man buys you a meal, you don't complain about the chili.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-12-2012, 04:53 AM   #7
I've heard about a mildew problem with all front-loaders. Is that true?
I've read that Miele and Siemens/Bosch are good. Would you guys agree?
Old 09-12-2012, 07:27 AM   #8
custom user
Rewards Points: 150
That's possible. I don't have that problem because I don't close the door all the way. It says cracked open, looks closed but isn't sealed shut. It just seemed like a common sense thing to do, I don't know what would happen otherwise.
Old 09-12-2012, 11:15 PM   #9
awd
The Maytag neptune from 10-15 yrs ago had serious problem (and CLass action lawsuit) with the mildew problem. They added drain holes in the seal to minimize the mildew problem but not completely eliminate.
Simple logic, if water stay on the seal (which any front loader washer will)of a period of time, it will cause mildew....simple solution, wipte it dry when after every load.
Front vs Top.... Front loader cost more and more prone to breakdown(IMHO). Mainly because they spin at much higher speed and the seal issue (Mildew and. too heavy a load) However, the operating cost is lower (less water, more efficient) and the main saving is in your dryer, Clocthes coming out of front loader is so much dryer than top load washer.
Any Top loader will last your 25 yrs. Front loader probably 15-18 yrs. again IMHO, YMMV. Good luck with your decision!
awd is offline   Reply With Quote
Old 09-13-2012, 08:54 AM   #10
#1 HAWKEYE FAN
In what world? Todays machines you'll be very lucky to get 10 -12 years tops with top loaders and the verdict is still out on the front loaders. I've replaced and worked on far more front load machines after only a few years use.
Old 09-13-2012, 08:55 AM   #11
#1 HAWKEYE FAN
yes, mold can be an issue with any front loader but a little maintenance and attention will go a long ways in preventing it.
Old 09-17-2012, 12:03 AM   #12
awd
it all depend on your definition on how long the washer last? If you;re talking abt No fixing/replacing wear and tear item, then nothing gonna last 25 yrs....
I don;t consider replacing a belt, a seal bellow as an end of life for a washer...again, YMMV or in this case, Your definition may vary!
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
Plumbing or Washing Machine Issue svaic00 Plumbing 4 08-06-2012 09:46 AM
recommendation for washing machine mazzonetv Appliances 1 10-20-2009 06:23 AM
