Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-23-2006, 01:10 PM   #1
Journeyman Plumber
Ron The Plumber's Avatar
Washing Machine Pumps
Hay Jeff,
What is the max height a washing machine can pump the water out at before it causes a strain and the wahers pump?
Fix it right the first time, so you won't have to fix it a 2nd time.
2008 Oregon Specialty Plumbing Codes
Ron The Plumber is offline   Reply With Quote
Old 12-23-2006, 03:59 PM   #2
jeff1's Avatar
Hi Ron...Happy Holidays
Each design/manufacture is sligtly different. Most say 5 feet is max, some will go up to 8 feet before crapping out. The one thing is the water in that hose will likely drain back into the machine once the washer shuts off, some have a small back check valve to help prevent that, some do not. Some washers ( Maytag is one ) have high volume pumps that can be purchased so they will do the 8 feet easily.
Another consideration is the washers speed, regular ( high speed ) moves the water out easier than the delicate ( slow speed ) does.
jeff.
Appliance Repair Aid
www.applianceaid.com
JRAppliance
www.jrappliance.ca
jeff1 is offline   Reply With Quote
More On This Topic
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about the proper use and maintenance of a pressure washer. This section of the pressure washer is the pump. These are the cylinders... Read More »
When you need to pump water to a distant field, sometimes it's not convenient to run the pump with electricity. In such an application, a solar pump works well. Fortunately, you can do this yourself. This eHow can help you get started. Read More »
Hi. Welcome to Expert Village. I'm Gretchen Soares and today we're going to be making a rag blanket. In this clip we're going to talk about the ragging effect and how we make it on this blanket. What makes that is when we wash and dry this blanket. It... Read More »
In this step we're actually going to wash the quilt and what this will do is it turns it from just a flat seam into kind of a fluffy and soft seam. So we'll wash it and dry it. So it's cotton, so we're going to wash it on, with cold water and we'll place... Read More »
Hi! I'm Molly Herring with Expert Village. I'm here telling you how to wash your jeans. Right now we're discussing setting the water level on your machine. It depends on how many items you load in your machine. On different washer and dryers the same... Read More »
FloodSafe Washing Machine Hoses IdahoBob Plumbing 8 07-26-2009 06:30 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
Washing machine - hot water supply only? Sosh Plumbing 4 07-11-2007 04:36 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 12:28 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 08:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
