Washing Machine Problems - Appliances - DIY Chatroom Home Improvement Forum
Old 12-21-2008, 02:06 PM   #1
washing machine problems
I have a maytag neptune front loader washing machine and when it is on the spin cycle it shakes like it has an unbalanced load in it. I put it in the spin cycle with no clothes in it and it does the same thing. Does anyone know what could be causing this? thanks
theltimatepartyjams is offline   Reply With Quote
Old 12-21-2008, 02:35 PM   #2
Eibwen
Possibly one of the roller for the drum is bad.
Check the owners/install instructions for balancing just to make sure thats not the issue. Normally level the front with the two adjustable legs. Then pick up the back and drop it slightly a few times to auto level the back two legs.
Sammy is offline   Reply With Quote
Old 12-21-2008, 02:42 PM   #3
I opened the back of it does anyone how how the open the front of the machine
Old 12-21-2008, 03:15 PM   #4
Eibwen
might check maytag.com if you dont have the owners manual for it.
Be sure to check consumeraffairs.com then slelect maytag. Looks like there has been major issues and a recall on that model.
Several issues including defective circuit boards causing spin overspeed and drums cracking/losing bearings.
Good Luck
Old 12-21-2008, 03:43 PM   #5
thanks
Old 12-21-2008, 04:11 PM   #6
Eibwen
Your welcome
Good GE luck with it.
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 08:47 PM
Washing machine lint filter Dragonladie Plumbing 4 10-19-2008 07:52 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
Hotpoint Washing Machine issue pjpjpjpj Appliances 3 03-07-2008 01:26 PM
External Lint Filter for Washing Machine ? Piney Appliances 2 05-03-2007 12:28 PM
