Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 09-15-2012, 08:41 AM   #1
washing machine maytag
machine is spinning but not fast enough to get all the water out
lemarble is offline   Reply With Quote
Old 09-15-2012, 08:44 AM   #2
Sounds like a slipping drive belt.
If you Google the make and model number of your washer lots of trouble shooting guides, manuals and parts break downs come up.
The Following 2 Users Say Thank You to joecaption For This Useful Post:
lemarble (09-15-2012)
Old 09-15-2012, 09:40 AM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
belt slipping, tub bearing getting tight, rusty motor carriage are 3 possible problems that come to mind
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 09-15-2012, 10:09 AM   #4
I've even seen a leaking pump seal cause it.
It was a tiny spray hitting the belt causing it to slip but it would not be enough to show up on the floor, the water would just evaperate when it hit the hot belt.
Old 09-16-2012, 06:29 PM   #5
Bombastic Idiot
notmrjohn's Avatar
Temporary fix for slipping belt is spray can of belt dressing. I really don't know how long the temporary is. Used it once on washer, lasted several years when other problems with washer lead to new machine B4 belt breakage or slippage recurrence. Have used it on table saw, again just once. Dressing supposedly can lead to belt weakening, but never had a problem. I have an almost full can of dressing, years old, but you can borry it if you want.
Measure twice, cut once.
Look at the nail, not the hammer. Watch the fence, not the blade.
If you hook your thumb over your belt you won't hit it with the hammer or leave it layin on the saw table.
notmrjohn is offline   Reply With Quote
Old 09-16-2012, 06:48 PM   #6
i fixed one that had a blockage of lint in the pump itself. the pump empties the washer, the spinning gets the water out of the clothes. i would look at the pump as others recommended, be it belt or pump or clogged hose.
Old 09-16-2012, 06:59 PM   #7
Bombastic Idiot
notmrjohn's Avatar
Good point ,Danny. My washer is hard connected to drain. Drain line or sewer blockages can prevent all water from draining. if its hardewares tite bearing, belt dressing is also pulley de-glazer.
Old 09-16-2012, 08:45 PM   #8
#1 HAWKEYE FAN
belt dressing on washer belts always a bad idea. Washer belts are designed to slip in the initial stages of the spin. If you put belt dressing on them they will cause motor overheating and usually cause the motor to kick out on the overload.
Old 09-16-2012, 11:59 PM   #9
awd
is this maytag neptune washer?
awd is offline   Reply With Quote
Old 09-17-2012, 01:55 AM   #10
Bombastic Idiot
notmrjohn's Avatar
Weak idler pulley spring? I dunno about this washer, some have a few holes for spring so you can adjust if spring gets weak or belt stretched.
Most one speed motor, belt driven things that start under load have some kind of slippage or speed adjustment provision. Sprung idler pulleys, transmissions and centrifical clutches assist in that.
"belt dressing on washer belts always a bad idea" its usually a bad idea on anything, you're basically disolving part of the belt. I'm sure an overly tight or "grippy" belt is not good for motor or other parts, but mine ran for years with no problems in drive train after belt dressing. Just sayin'.
Was a Kenmore, don't remember what it really was, but found lots under various names all lookin the same set out on curbs. I'd stop, take look and if had right parts in good shape into truck and hauled home. Canabalized for long time. Finally Mrsnot got tired of washers hidden behind house, and when timer went. it was out on our curb. Less than hour B4 someone looking for parts came along. Was expecting scrap man, he showed up week later and hauled away bare bones of others. Wave of fear went thru dryers sittin out there, were they next? Yes, soon ruthlessly stripped of parts and gone.
awd, something particular about neptune?
lemarble, sorry about all that With washer unplugged, back off, reach under an see if belt is loose, just pull it around pulleys and see if it slides, push or pull middle of belt horizontally and see if it moves too much out of straight line. Sorta like this. With belt off, look to see how it goes around pulleys and against idler so you can put it back on right (voice of experience here) give tub some spins with hands, listen and feel for roughness or sounds from bearings or ant rollers it may have.Just rough tests, but may give you clue.
Old 09-17-2012, 10:12 AM   #11
Bombastic Idiot
notmrjohn's Avatar
Never mind,awd, I googled it. Holey Moley! But it reminded me that one of us should have thought to ask if it was top or front loader. To ask the marble if it was positive observation that drum was spinning slow or assumption drawn from water still in tub or ideed if "not get all the water out" meant water out of tub or that clothes were still wet. If I was just spinning my pulleies on all that belt, pulley and bearing stuff and it is spinning fine, then its time to go pump, hoses, drainage, maybe even timer route.
Problem with Candy Smart CTDF 1007 Washing Machine (European washing machine) PBEnglish Appliances 4 09-11-2012 01:07 PM
Can I turn off hot water to Washing Machine? okk Plumbing 12 08-10-2012 08:14 PM
maytag washing machine ajtapia Appliances 1 02-23-2012 10:41 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 11:51 PM
