Washing Machine Leaks Into Drum - Appliances - DIY Chatroom Home Improvement Forum
Old 03-20-2014, 10:50 AM   #1
Rewards Points: 43
Washing Machine Leaks into Drum
My Kenmore washing machine leaks from the supply into the drum, most noticeable after doing a load of clothes. We end up turning off the water supply after each load to avoid the "drip" noise, which is a PITA and gets the clothes wet if you don't pull them out quick.
Is there a gasket or something that can be replaced?
Thanks in advance,
Al
AlleyG is offline   Reply With Quote
Old 03-20-2014, 11:21 AM   #2
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
model number might help. How old is this machine? sounds like the supply solenoid needs to be replaced as it is not closing completely.
Gregg M.
gmaint is offline   Reply With Quote
Old 03-21-2014, 03:36 PM   #3
Rewards Points: 43
It is a Kenmore 80 Series, 15+ yrs old. Model # 110.27812690.
Thanks for any tips.
Al
Old 03-21-2014, 03:42 PM   #4
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
Al,
Still sounds like the fill solenoid has grit in it. This will cause this type of leak.
Fairly easy to change out.
Gregg M.
Old 03-21-2014, 03:46 PM   #5
Rewards Points: 6,652
Another vote for the Solenoid. That old, there is all kind of Calcium build up on the valve. You are lucky that the Transmission has not gone out on it.
Old 03-21-2014, 03:48 PM   #6
24+ years of fixin'
gmaint's Avatar
Rewards Points: 340
gregz,
you had to go ahead and mention that didn't you?
Gregg M.
washing machine problem wengang1 Plumbing 9 01-11-2014 12:49 PM
Washing machine overflows laundry sink-venting problem? dublozrow Plumbing 10 06-27-2013 02:01 PM
Vinegar in the Washing machine wraiththe Plumbing 6 01-12-2012 11:51 PM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 01:41 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
