#1 |
Washing Machine issues
ITs been having issues where it sounds like its out of balance on the spin cycle, really bad.
Now, it doesnt even spin. Is this possibly just a belt replacement issue? Thanks! |
#2 |
could be a belt. some just have a plastic coupler on the motor that cracks. thats what happened to ours.
#3 |
When the spin cycle still worked, it would shake pretty badly during the spin cycle. Like there was something missing that used to stabilize the basket during spinning.
#4 |
#1 HAWKEYE FAN
make and model would sure be helpful
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"........... |
#5 |
It is an RCA YBXR1060V1WW
I took the cover off, spun the motor pulley. Tried the spin cycle, and now it is spinning. But it is still shaking, and LOUD during the spin cycle. Looks like there are stabilizing connections, not sure if these need to be tightened/adjusted. Thanks for any help. |
#6 |
We had a Maytag that started shaking when spinning and real loud banging...turned out a chink of plastic had broken off that I guess kept the basket somewhat centered. Can't buy it anywhere, but a service repairman had us up and going in a week.
#7 |
#1 HAWKEYE FAN
what do you mean by loud, does it sound like a bad bearing?
#8 |
Washing Machine issues |
#9 |
So, for the sake of clarity, it doesn't sound like a jet airplane, the noise is the thuds from the drum banging around?
#10 | |
Washing Machine issuesQuote:
http://www.youtube.com/watch?v=T-pud...ature=youtu.be Reading up on this, it is drum the bearing isnt it? Last edited by dbower; 12-30-2011 at 01:21 PM. |
#11 |
#12 |
Found a parts list online... Can anyone confirm which parts I need for this repair? From what I can tell, I need items 311, 313, & 314. Does that sound right?
http://www.appliance-parts-warehouse...arts-38544.cfm Thanks for any help!! Last edited by dbower; 01-04-2012 at 12:14 PM. |
#13 |
if that's your prob'-you need #325 also.
#14 | |
Is there a way to confirm whether that is the issue? I posted a vid above. http://www.youtube.com/watch?v=T-pud...ature=youtu.be |
#15 |
pull the agt' and see if tub nut is loose-if so you have to pull basket and replace those parts-[instructions/tech sheet are in control area]-nut,split ring,washer. tightening won't last. can also just wiggle basket to see if loose.
| Display Modes | |
| how to fix washing machine front spring | rvegab00 | Appliances | 2 | 04-11-2012 04:30 AM |
| Trouble with washing machine drainage | wfischer | Plumbing | 3 | 05-15-2011 06:10 PM |
| Washing machine and dedicated circuit.... ? | CoconutPete | Electrical | 15 | 11-16-2010 09:02 PM |
| Tapping water line and drain from sink for washing machine? | RyanD | Plumbing | 2 | 06-27-2009 09:25 PM |
| Hooking up a washing machine?? | teachtech | Plumbing | 1 | 03-11-2008 12:17 PM |
