-   -   Washing Machine issues (http://www.diychatroom.com/f47/washing-machine-issues-128076/)
dbower 12-29-2011 01:36 PM
ITs been having issues where it sounds like its out of balance on the spin cycle, really bad.
Now, it doesnt even spin. Is this possibly just a belt replacement issue?
Thanks!
DannyT 12-29-2011 01:48 PM
could be a belt. some just have a plastic coupler on the motor that cracks. thats what happened to ours.
dbower 12-29-2011 04:51 PM
When the spin cycle still worked, it would shake pretty badly during the spin cycle. Like there was something missing that used to stabilize the basket during spinning.
hardwareman 12-29-2011 06:27 PM
make and model would sure be helpful
dbower 12-29-2011 06:54 PM
It is an RCA YBXR1060V1WW
I took the cover off, spun the motor pulley. Tried the spin cycle, and now it is spinning.
But it is still shaking, and LOUD during the spin cycle. Looks like there are stabilizing connections, not sure if these need to be tightened/adjusted.
Thanks for any help.
dougp23 12-29-2011 06:57 PM
We had a Maytag that started shaking when spinning and real loud banging...turned out a chink of plastic had broken off that I guess kept the basket somewhat centered. Can't buy it anywhere, but a service repairman had us up and going in a week.
hardwareman 12-29-2011 07:31 PM
what do you mean by loud, does it sound like a bad bearing?
dbower 12-29-2011 08:09 PM
No, not a bearing. Just loud from the machine itself vibrating.
jfrotten 12-30-2011 08:12 AM
So, for the sake of clarity, it doesn't sound like a jet airplane, the noise is the thuds from the drum banging around?
dbower 12-30-2011 12:11 PM
I made a video. Vid Quality is not great, but notice how off center the spin is, with no load.
http://www.youtube.com/watch?v=T-pud...ature=youtu.be
Reading up on this, it is drum the bearing isnt it?
dbower 01-02-2012 02:01 PM
dbower 01-04-2012 10:55 AM
Originally Posted by dbower (Post 810207)
Found a parts list online... Can anyone confirm which parts I need for this repair? From what I can tell, I need items 311, 313, & 314. Does that sound right?
http://www.appliance-parts-warehouse...arts-38544.cfm
Thanks for any help!! :thumbsup:
Jacques 01-06-2012 07:10 AM
if that's your prob'-you need #325 also.
dbower 01-06-2012 09:26 AM
Originally Posted by AdelieBailey (Post 814121)
You might want to have it checked in the service center. Is it still covered by the warranty?
no it is not.
Is there a way to confirm whether that is the issue? I posted a vid above.
Jacques 01-07-2012 09:59 AM
pull the agt' and see if tub nut is loose-if so you have to pull basket and replace those parts-[instructions/tech sheet are in control area]-nut,split ring,washer. tightening won't last. can also just wiggle basket to see if loose.
