Washing Machine Hose Fittings - Appliances - DIY Chatroom Home Improvement Forum
Old 01-20-2011, 06:37 PM   #1
washing machine hose fittings
Where can i find a 90 degree fitting (just the fitting) for the hot and cold hoses.
Jc709 is offline   Reply With Quote
Old 01-20-2011, 06:45 PM   #2
the Musigician
DangerMouse's Avatar
Your local hardware store should have those, or the big box stores.
They also have hoses with a 90 turn on one end. Would those work for you?
DM
Old 01-20-2011, 06:50 PM   #3
Best recommendation is a shut-off valve made specially for washers. Both cold and hot shut off on one throw of the stick. Takes all pressure off the lines so they can never burst.
But... it needs to be sweated in and hot and cold copper pipes to be aligned.
diyorpay is offline   Reply With Quote
Hose pops off my Kenmore portable washing machine DBluestone Appliances 0 11-08-2010 12:52 PM
Drain hose stuck on washing machine savingedmund Plumbing 3 05-10-2009 10:19 AM
Cold water hose - washing machine cmcgowan Plumbing 1 01-08-2009 10:13 AM
Washing Machine Dripping at Hose Connector..HELP! kswoot Plumbing 19 10-24-2008 08:12 PM
Washing machine drain hose morrisp Plumbing 3 09-01-2006 07:24 PM
