Washing Machine Drain Pipe Over Flowing - Appliances - DIY Chatroom Home Improvement Forum
Old 09-30-2012, 06:02 PM   #1
washing machine drain pipe over flowing
Hello all,
I know this has been posted before but i have to ask this. First of all the washer I own is over ten years old. last winter i had the pipes cleaned by a plumbing company. about six months after winter my washing machine starts to over flow from the drain tube. to stop the washer from overflowing I have to sit by the washer and when it starts to over flow I have to open the lid and allow it to drain then close the lid only to repeat the process again till the spin cycle starts then it will drain on its own. I called roto rooter to come check things out but with out any clothes in the washer the drain pipes will not over flow. I checked out the washer (drain basket) and found no clogs of any kind. No other drain backs up in the house. My question is should I have the pipes done again because of the tree roots that broke through the pipes or should I up date my washer?
thanks
peskygnat is offline   Reply With Quote
Old 09-30-2012, 07:50 PM   #2
Rewards Points: 13,300
Most likly it's pluging up in the trap for the washing machine.
Just run a snake down the drain.
Old 09-30-2012, 07:56 PM   #3
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
hire a competent plumber who knows how to find a clog. Its very obvious you have a partial clog from the stand pipe to where it hooks into the main drain pipe. Or do as Joe said first and run a drain auger down the stand pipe first
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Washing machine drain hose - how high can it pump? sheslostcontrol Plumbing 5 01-30-2012 09:39 AM
AC drain pipe vent trap going dry - sewage smell denemante Plumbing 6 04-26-2011 07:52 PM
Corrugated Washing Machine Pipe considiner Appliances 0 01-01-2010 05:14 PM
Washing machine drain line noise MikeKy55 Plumbing 2 12-03-2009 09:19 PM
Washing Machine Drain mqcarpenter Plumbing 3 11-20-2008 08:47 PM
