Washing Machine - Appliances - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 10:28 PM   #1
washing machine
My Kitchen Aid washer, Model KAWS700LQ0, will go thru every cycle with no problem, but when it gets to the spin cycle, will not spin. I changed the lid switch, and now it will spin, but only when its empty. Any ideas?
Jenn23 is offline   Reply With Quote
Old 12-28-2011, 10:42 PM   #2
loose or worn belt maybe. some have belts some dont.
The Following User Says Thank You to DannyT For This Useful Post:
Jenn23 (12-28-2011)
Old 12-29-2011, 07:05 AM   #3
Agitations fine?..probably trans leaking oil on clutch..needs clutch cleaned up and trans replaced...if no sign of oil=clutch is worn out.
Jacques is offline   Reply With Quote
Old 12-29-2011, 08:21 AM   #4
Rewards Points: 152
Following are a couple of excerpts from my normal source for appliance parts, pertaining to your machine...
"Part # 1195967 drive motor coupler. New style with metal sleeves for added strength. This version replaces all previous motor coupler styles and versions. For direct drive washing machines."
"Common symptom of failed coupler is washer will fill, not agitate or spin but will drain the water from the tub."
Not sure if that helps, but sounds like it is worth checking out.
Old 12-29-2011, 11:56 AM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
if it agitates ok and does spin then the coupling is not the problem. Definitely a clutch problem
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 03:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 05:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 08:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 08:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 11:17 AM
