Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-06-2011, 12:35 PM   #1
Washing Machine
My GE washer will not spin for the small load cycle, but "will" spin for larger loads.
Stamati45 is offline   Reply With Quote
Old 08-07-2011, 10:21 PM   #2
Washing Machine
What kind of machine are we dealing with here? Front or top loader. Are the controls mechanical or electric/digital.
When you say smaller load, is it the load size switch, or are you using a shorter cycle? Like heavy, medium, light?
Master of Cold is offline   Reply With Quote
Old 08-07-2011, 11:02 PM   #3
Washing Machine
It is a GE Top Load, approx 6 yrs old. Small load meaning "size" of load.
Electrical timer - it's a new one I installed. Washing machine works fine for all the cycles except the small load size; it will not go into the spin cycle.
Old 08-07-2011, 11:59 PM   #4
Washing Machine
The motor controller (im assuming this is a direct drive, no transmission) has load sensing. It uses the motor amperage to see how full the basket is and determine the spin cycle time.
I don't know how much this part is, but im pretty sure your better off washing with large load option untill you buy a new one. My last one had the motor burn out. I paid 275 for the washer new. The replacement motor was $565.
how to fix washing machine front spring rvegab00 Appliances 2 04-11-2012 04:30 AM
Trouble with washing machine drainage wfischer Plumbing 3 05-15-2011 06:10 PM
Washing machine and dedicated circuit.... ? CoconutPete Electrical 15 11-16-2010 09:02 PM
Tapping water line and drain from sink for washing machine? RyanD Plumbing 2 06-27-2009 09:25 PM
Hooking up a washing machine?? teachtech Plumbing 1 03-11-2008 12:17 PM
