Washers Timer Removal - Appliances - DIY Chatroom Home Improvement Forum
Old 03-22-2009, 04:57 PM   #1
Washers timer removal
How do I remove the timer from a Whirlpool Washer with Model LSR6232LQ0? I have tried turning the knob counter clockwise and it just ratchets and will nott loosen. Also how do I remove the top after I have the knobs off from the timer, fill level and temperature setting?
Thank you
God Bless
Fred
Uthpstr404 is offline   Reply With Quote
Old 03-22-2009, 05:52 PM   #2
Gently pull the knob forward and you will likley find a set of screws behind it to remove the timer.
Chemist1961 is offline   Reply With Quote
Old 03-22-2009, 06:13 PM   #3
No set screw either..... I have the Knob then a clear plastic piece that covers the arrow that turns to show what cycle the machine is at. Does the knob just pull off, or could it be jammed or stripped out? If this is the case, any suggestions to help me remove the knob?
Old 03-23-2009, 05:19 PM   #4
Thanks for the advice and help....... Have parts removed and will have put back together when parts arrive.
Once again Thanks for the advice.
God Bless
Fred
Help My Admiral Refrigerator is leaking water Cuwillis Appliances 10 03-25-2014 08:21 AM
Adding a Wireless Sprinkler Timer feature... markharris Landscaping & Lawn Care 1 03-02-2009 01:41 PM
New project: removal of old fireplace-replace with a new fireplace! MrShadetree0222 Building & Construction 14 10-16-2008 06:12 PM
Timer Installation lpmike82 Electrical 3 06-21-2008 02:58 PM
Lead paint removal Luken8r Painting 3 05-15-2008 07:05 PM
