Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-01-2012, 09:43 AM   #1
Washer won't start
Hello everyone, my girlfriend has a Kenmore stacked washer/dryer combo unit Super Capacity. Not sure of the model number as I can find no info on it.
My problem... When I turn the knob to the desired cycle (regular, permanent press, delicates) I want to use and pull the knob out to start, nothing happens. When I turn the knob to any of the rinse cycles in the desired cycle, the tub starts to fill.
Any answers would be greatly appreciated.
Thanks so much.
MAV2595 is offline   Reply With Quote
Old 01-03-2012, 08:58 AM   #2
sleepyg's Avatar
Washer won't start
May get flamed for this, but just put on a setting that works and then let the cycle run its course. Then try the other cycles and see if they work.
sleepyg is offline   Reply With Quote
The Following User Says Thank You to sleepyg For This Useful Post:
MAV2595 (01-03-2012)
Old 01-03-2012, 11:36 AM   #3
Washer won't start
Disconnect the hot and cold water lines and make sure that the screens in the end of the houses aren't clogged. It sounds like one of your hoses may be clogged...
jfrotten is offline   Reply With Quote
Old 01-04-2012, 06:49 AM   #4
Washer won't start
Thx Jfrotten. I will give that a try, although, if the tub begins to fill on the rinse cycle it would seem they shouldn't be clogged should they?
I did order another timer switch. Would be nice to be able to return that.
Old 01-04-2012, 09:20 AM   #5
Washer won't start
Depending on your settings, the first fill may be with hot water (the clogged line) and the rinse fill is with cold water (the unclogged line). This would produce the problem you're having and it's one I've seen before. This may not be your problem but I believe in checking the easy stuff first.
Old 01-04-2012, 09:38 AM   #6
Washer won't start
Thx for that useful bit of information J as I am certainly not the Maytag repairman.
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 12:13 PM
washer and Clothes coming out of washer stink. rsplash40 Appliances 11 07-03-2009 12:05 PM
washer will not start badnews582008 Appliances 1 05-25-2009 12:46 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
