Washer Wont Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 04-01-2015, 08:51 AM   #1
msmomoftwins's Avatar
Rewards Points: 8
washer wont spin
my washer fills and drains but wont spin or agitate. Is the motor or the belt? Please help.
msmomoftwins is offline   Reply With Quote
Old 04-01-2015, 09:05 AM   #2
Rewards Points: 14,306
Make model #?
Often times it's as simple as the door switch.
Old 04-01-2015, 09:51 AM   #3
Rewards Points: 8
Kenmore heavy duty 70 series model 110. washer wont go through cycles (i.e. Wont drain if door is open) So I know that is not the problem.
Old 04-01-2015, 10:35 AM   #4
Rewards Points: 137
Probably a faulty motor coupler. You need to remove the cabinet to gain access.
thefixer56 is offline   Reply With Quote
Old 04-01-2015, 12:00 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
that washer does not have a belt it has a motor coupler between the motor and transmission. Fairly simple fix. Watch the video thefixer posted.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 04-03-2015, 04:46 PM   #6
Rewards Points: 8
how do you tell how to order the right coupler for my model of washer
Old 04-03-2015, 07:26 PM   #7
Rewards Points: 350
The fixer already did it for you.
Click on the picture of coupler in the lower left hand corner of the video while it's playing, it will say but this part now, it will take you right to website to order it.
jmon is offline   Reply With Quote
Old 04-03-2015, 09:36 PM   #8
Rewards Points: 6,652
They are universal. You can order them through repairclinic.com. I had to lay my Kenmore on its side to change one out on it, along with the transmission, because it was burned out from my wife washing a sleeping bag in it.
Old 04-04-2015, 07:27 AM   #9
Rewards Points: 137
Although interchangeable, there are currently three different versions of these couplers. Part number 285753, 285753A which is the improved version with the metal inserts and there is a heavy duty version part number 285852.
Old 04-04-2015, 09:43 AM   #10
Rewards Points: 8
ok thanks guys
The Following User Says Thank You to msmomoftwins For This Useful Post:
jmon (04-04-2015)
Old 04-04-2015, 11:12 AM   #11
Rewards Points: 350
Your welcome.
Frigidaire Affinity front loading washer 2006 model-won't spin final spin? imola ghost Appliances 9 10-23-2015 04:23 AM
Kenmore washer spin speeds? Ultrarunner2017 Appliances 0 12-09-2013 02:22 PM
GE Washer will not perform final spin joeycranston Appliances 6 01-18-2010 11:06 PM
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
