Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 08-23-2008, 04:33 PM   #1
Washer tray drain plug
Our washer and dryer, in a utility room on the first floor, doesn't have a drain plug in the floor. So we want to buy a tray to put under the washer that has a side drain plug. We've been to a lot of hardware stores, but all the washer trays have the drain plug in the bottom. Any ideas on what types of stores to check?
proofer is offline   Reply With Quote
Old 08-24-2008, 08:30 AM   #2
jeff1's Avatar
Hi,
All that I have seen are a floor drain. -May- need to add your own side drain if that is what you need...
Washing Machine Water Spill / Leak Preventer Floor Tray
jeff.
Appliance Repair Aid
JRAppliance
jeff1 is offline   Reply With Quote
Old 08-24-2008, 11:22 AM   #3
I was really hoping they made a side drain washer floor tray. This area doesn't have a floor drain because this current utility closet was once the coat closet, so it wasn't initially set up for that. Also, the floor is now completely tiled. Thanks for responding.
Old 08-24-2008, 12:00 PM   #4
Whatamess
The picture looks like it has 3 different side positions to install the drain fitting. I may be wrong.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-24-2008, 01:09 PM   #5
jeff1's Avatar
Didn't want to say there was a side spot but the pic does appear to have different positions but the description...."Optional floor drain connection included"....just mentioned a floor drain!?
jeff.
JRAppliance
Old 08-24-2008, 09:53 PM   #6
Floor pans were originally made from metal. Why not have a tinsmith make one for you with a side opening!
Kenmore washer won't drain diggitydog Appliances 3 10-16-2010 11:46 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-05-2008 11:35 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
washer drain pipe paydelady Plumbing 3 11-13-2007 01:27 AM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
