Washer Spins Empty - Appliances - DIY Chatroom Home Improvement Forum
Old 07-03-2010, 07:25 AM   #1
Washer spins empty
My ge washer will spin if empty- i must manually take the wet clothes out, give it help to spin the tub manually to get it going , and then add the clothes after it starts spinning one by one. This is crazy.could it just be the lid switch? I put a plastic clothes hanger in the hole to start the spin with the lid open. You hear the click of the switch engaging. It just wont start the spin cycle by itself.i have to manually turn the tub and then no problem, it starts spining like crazy. If this could be a little fix i can do it ,a bigger problem,and forget it. Help !
BIGMAMMALUKE is offline   Reply With Quote
Old 07-03-2010, 08:34 AM   #2
the Musigician
DangerMouse's Avatar
Hi and welcome to the forum.
Without more details, I'd guess a loose/worn out drive belt?
That's what I'd be HOPING for anyways, it's the simplest to fix!
DM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
GE Profile Washer Model WPRE6100G0WT neither agitates nor spins tammy2006 Appliances 5 02-13-2010 01:33 PM
Moving Washer and Dryer upstairs from basement pennypoopie General DIY Discussions 3 08-23-2009 05:29 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
Maytag Washer Spins intermittenltly. matrcor Appliances 4 07-04-2008 09:08 PM
