Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-28-2008, 07:00 PM   #1
washer quit working
I have a Whirlpool top load direct drive model# LSW9700PQ0
While running a cycle the machine ran its timer to the end but the tub remained full of water. I tried to restart the cycle and I hear some buzzing and some sort of grinding noise at the top of the unit near the timer area. I can turn the timer and try to engage and it makes this same noise at every position on the dial but the tub will not agitate nor will the water drain.
Help...
machineguy is offline   Reply With Quote
Old 12-28-2008, 08:42 PM   #2
washer quit working
Need info. Are you SURE the noise is from control panel? Does same result from : wash, rinse, spin selections of dial? We can diagnose this if yr game to try.
Rainsfordwaters is offline   Reply With Quote
Old 01-05-2009, 12:48 AM   #3
washer quit working
is the hose plaugged? it doesn't drain at all? more info if possible, pls
wilsonfrench is offline   Reply With Quote
Power Washer Chem Feed Not Working robertr4836 Tools 11 11-24-2012 09:43 PM
windsheild washer not working lemoncoke Automotive Repairs 5 12-13-2008 12:52 PM
Clothes washer quit working Sean94 Appliances 10 08-03-2008 10:28 PM
Dimmer switch quit working Umabean Electrical 4 07-09-2008 02:25 PM
Outlet in garage quit working Thirdeye Electrical 10 07-01-2007 11:32 PM
