Washer Not Spinning Water Our Properly - Appliances - DIY Chatroom Home Improvement Forum
Old 01-07-2012, 10:18 AM   #1
washer not spinning water our properly
I have a washer that is about 25 yrs old and it doesnt seem to spin the water out properly every time...doesnt make a difference of load size.....the model no. is la7680xmwo..can anyone help me
sterling43 is offline   Reply With Quote
Old 01-09-2012, 07:46 AM   #2
Whoa! that's an 'old betsy'. does it always spin? most logical is; belt loose[should deflect from mid-point 1/2"]. or water dripping onto belt from tub leak. great washer but you're on borrowed time.
Jacques is offline   Reply With Quote
Old 01-09-2012, 12:39 PM   #3
I had a problem with an infant sock getting into the pump at the bottom of the bin and clogging it... when I removed it my machine started pumping water again. We use a mesh bag for anything small now. The pump could also just be getting worn out and might need to be replaced (which would probably be a big job if you can even find a compatible part).
I just read this article the other day from lifehacker. According to them it might be more price effective to switch to a new energy star model since you've got a pretty old unit. http://lifehacker.com/5873658/what-a...orth-upgrading
teststrips is offline   Reply With Quote
Washer not spinning out water Hkarp79 Appliances 18 10-18-2012 02:39 PM
Preference for installing tub spout? dolvio Plumbing 7 02-11-2009 10:53 PM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 07:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 10:31 AM
