Washer Not Spinning Out Water - Appliances - Page 2 - DIY Chatroom Home Improvement Forum
Old 02-11-2011, 04:59 AM   #16
Maybe the spin is too gentle.
londeed_leung is offline   Reply With Quote
Old 02-11-2011, 08:15 AM   #17
Rewards Points: 5,336
What exactly are you trying to say here?
Ron
Old 02-11-2011, 10:09 AM   #18
Rewards Points: 530
Been a very long time, but what is the purpose of a "gentle" spin? Does it spin slowe but longer to get as much water out as possible?
Old 10-18-2012, 03:39 PM   #19
Whirlpool Imperial stylemaster 4213964 - spin stops
I inherited a Whirlpool (Imperial) Stylemaster 4213964 (from house I bought) that appears to be maybe from ~1992 (I have Use & Care Guide). Recently it would not completely empty the water in from a standard wash cycle. I tried to set it back to Spin cycle but it did not drain again. Seems to spin fine but not for as long as it should.
I then put it back (using the Cycle & Time knob) to Spin but manually held down the Spin Speed selector knob and it would spin (as long as I held it down) for the few minutes until the cycle ended and the water was gone.
I wonder if this is a timer issue with the Cycle & Time knob?
And if so, where can I get a part and how easy is it to do myself?
Just found model number....LSP8245AWO (or maybe that last digit is a Zero)
Thx
desmo907 is offline   Reply With Quote
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Washer water supply valves won't turn jerome8283 Plumbing 2 11-01-2009 10:38 AM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
Is 1/2 Pex more restrictive than 1/2 copper? twilightcall Plumbing 19 06-24-2008 08:32 AM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
