Washer Noise - Appliances - DIY Chatroom Home Improvement Forum
Old 02-22-2011, 01:24 PM   #1
Rewards Points: 91
washer noise
this noise starting coming from my top load washer on the spin cycles, and i think it is coming from the motor or pulley under it. Anyone know how to fix or pinpoint this issue? it has gotten a little worse and it is louder with a bigger load. here is a video with the sound, can't really see but i opened up the front of it.
http://s1087.photobucket.com/albums/..._converted.mp4
no_Wedge is offline   Reply With Quote
Old 02-22-2011, 09:32 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,596
imposable to say, your video is terrible,but it sounds like either a bad pulley, a bad idler, or bad belt
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 02-25-2011, 10:28 PM   #3
Rewards Points: 530
Does that machine even have a belt? Bad video, but reminds me of a direct drive. If so, check the motor coupler.
Old 02-25-2011, 10:41 PM   #4
Rewards Points: 91
it does have belt i found the problem, it is a bad water pump, the bearing is coming apart and has caused the shaft to bend on the pump.
Old 02-26-2011, 10:41 AM   #5
Rewards Points: 530
Rattling Noise from Roof when windy drgillian Roofing/Siding 3 02-18-2011 10:05 AM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
GE Washer WVSR1060A0WW noise problem gflippen Appliances 0 03-03-2010 09:23 AM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
GE washer machine noise superiorbuilt4u Appliances 2 12-18-2007 08:27 AM
