Washer Machine Problems. - Appliances - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 09:35 PM   #1
washer machine problems.
my washing machine cold water won't work, won't go in the washer hot water pours in cold water drips in. how do i fix this.,
kimmer is offline   Reply With Quote
Old 08-20-2011, 10:59 PM   #2
some washing machines have a screen inside the connection for the hoses. check there and some hoses used to have screens in them also. if the hoses are old you should install new ones anyway while you have them off to clean the screen. was it working fine and then just stopped or did it slow down gradually?
Old 08-21-2011, 05:26 PM   #3
clean clothes are overrated.
UFoPilot is offline   Reply With Quote
Old 08-22-2011, 12:00 AM   #4
Long-Time DIYer
Mike Swearingen's Avatar
The problem is likely in the screen of the cold water hose. If they are more than five years old, replace both hoses with the stainless steel kind with new screens.
If it isn't the hoses, the problem may be in the valve on t he washing machine that the hoses are connected to. You can get a new one for your washer make and model number at your appliance dealer. They are easy to replace.
Good Luck!
Mike
Mike Swearingen is offline   Reply With Quote
Old 08-22-2011, 11:06 AM   #5
You can find the part here http://www.appliancepartspros.com/
here's a video on how to change the valve. http://www.appliancepartspros.com/Ap...ap3094541.aspx
2nd floor washing machine with no trap katzenbe Plumbing 9 06-21-2011 12:35 PM
Building a Washing Machine Drain Pan wiz561 General DIY Discussions 8 04-03-2011 02:51 PM
Washing Machine Overflowing Suddenly After Working Fine For Months tonywolfe Plumbing 5 08-01-2010 01:34 PM
washing machine problems theltimatepartyjams Appliances 5 12-21-2008 03:11 PM
GE washer machine noise superiorbuilt4u Appliances 2 12-18-2007 07:27 AM
