Washer: Loose Belt - Won't Spin - Appliances - DIY Chatroom Home Improvement Forum
Old 05-30-2009, 02:09 PM   #1
Handy
Washer: Loose belt - won't spin
F22C445ES0 Top-Loading Washing Machine made by White for Frigidaire
Tensioner doesn't want to tighten belt?
This is a sudden problem, one day we washed fine, next day she won't spin. If I stick a screw driver behind the tensioner ("idler pulley"), she agitates just fine and spins just fine and fast-spins just fine.
I've seen worn auto belts and this one just doesn't look worn at all, but acts like it is too loose. Could it be as simple as replacing the belt?
Attached is a crude diagram.
The F22C445ES0 is one of the newer ones (the parts book is dated 1996) with the pump on the left side and the transmission itself moves when it agitates. Is the idler pulley supposed to provide tension, or just take up slack?
Washer: Loose belt - won't spin-f22c445e.jpg
Hemingway is offline   Reply With Quote
Old 05-30-2009, 02:49 PM   #2
the Musigician
DangerMouse's Avatar
had the same problem recently. used belt dressing, it worked fine.... for a few weeks.
got new belt and it worked fine....for a few weeks.
then it finally stopped agitating AND spinning.... got new washer.... works fine.... for now....
DM
Old 05-30-2009, 04:14 PM   #3
"Higher tension reduces slip, which increases belt life and mechanical efficiency"
Old 06-02-2009, 08:59 AM   #4
Handy
Okay yes so I found the Tension Spring on the Idler Pulley was sheered off. Ordered a new one for replacement this weekend. Question: tight quarters, how to access? Is there a way to lift the Dome Assembly up a little?
Old 06-02-2009, 11:20 AM   #5
Dunno', I'd be more worried about getting cut on the sheet metal edges.
Tribles and others sells "Repair Master" books for $12 or so if this repair is really tricky.
Old 06-06-2009, 05:35 PM   #6
Handy
The whole tub and motor are suspended by springs so I just got a flat bar and using the edge of the bottom of the washer as a fulcrum, lifted the whole thing enough to be able to shove a 2x4 under there at the base of the dome. It was still tight getting the lock washer off the bottom of the spring axel, but it popped off by pushing the ends with two screwdrivers.
Tags
frigidaire , washer
GE washer No spin when loaded SPSNEXPERT Appliances 4 06-29-2009 12:39 AM
My GE Washer Model #WJXR2080T8WW Will not Spin TDM Appliances 2 01-17-2009 08:56 PM
Maytag washer spin cycle problems. billmac Appliances 1 07-16-2008 04:03 PM
washer spin cycle seems wrong markm Appliances 5 01-04-2008 01:10 PM
