Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 03-06-2009, 02:49 PM   #1
Washer leaks
help my washer is leaking from underneath. What could it be? And is it worth fixing?
thank you, beth
bethlex123 is offline   Reply With Quote
Old 03-06-2009, 08:29 PM   #2
Crazy, but lovable
flyboy2610's Avatar
Washer leaks
It could be the pump. Around $150 to have fixed. Or it could be the tub seal.
Is this a top loader or a front loader?
flyboy2610 is offline   Reply With Quote
Old 03-12-2009, 02:15 PM   #3
Newbie Bill
Washer leaks
Could also be the hoses leaking.
drtbk4ever is offline   Reply With Quote
Old 03-14-2009, 07:09 AM   #4
Washer leaks
Check the hoses where they meet the pump. My old pump rotted out at the elbow from retained water due to sludge inside, phosphates , balls of thread , etc. I went to move the unit and could see a leak in the side of the pump where the hose attached.
Chemist1961 is offline   Reply With Quote
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
Washer Drain line extention Born In America Appliances 1 02-28-2009 04:55 PM
220V Washer 3-pronged to 220V dryer-outlet Primergy Electrical 19 03-27-2008 11:40 PM
Washer drain peloncito Appliances 7 08-04-2007 01:56 AM
Location of 220 and 110 outlets for dryer and washer JAJJ Electrical 2 08-07-2006 10:16 PM
