Washer Help Needed - Appliances - DIY Chatroom Home Improvement Forum
Old 07-17-2011, 11:41 AM   #1
Talking
washer help needed
Hi,
The water comes into the washer just as it is supposed to do. However, it never stops running! When this started happening, I turned the washer off for fear of an overflow! Because the water never stops running, the washer never begins agitating. Can this washer be saved?
Beth
lmbrbrdg is offline   Reply With Quote
Installing washer and dryer in basement in former tub enclosure. dj_backq Building & Construction 8 11-02-2010 09:56 PM
Washer Drain Pipe Install somewhatsketchy Plumbing 0 10-10-2010 12:13 PM
ugh.... my kenmore washer won't fill with water! diy'er on LI Appliances 6 09-05-2010 08:28 PM
Looking for Washer drain solution RobertSch Plumbing 5 01-28-2009 10:08 AM
Moving Washer in Utility Room orvym Plumbing 2 11-21-2008 06:40 PM
