Washer/Dryer Pedestal Good Idea? - Appliances - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 02:25 PM   #1
Washer/Dryer pedestal good idea?
We have a Samsung high efficiency washer/dryer. Right now they are just sitting on the floor and seem to be working fine, but since we have slight back problems we might want to invest in getting pedestals for them. I heard this is a bad idea since it causes them to shake more then they should.
dinosaur1 is offline   Reply With Quote
Old 12-03-2011, 04:21 PM   #2
Rewards Points: 6,652
Depends on how you like to bend down to get in. You can build your own pedestal/platform, that they could sit on out of Pressure Treated wood.
Old 12-04-2011, 12:04 AM   #3
Rewards Points: 502
you could build a solid platform an there would be no added shaking.
forresth is offline   Reply With Quote
Old 12-04-2011, 01:40 PM   #4
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
by all means invest in the pedestals, if they are installed correctly, leveled and solid they will not make the washer vibrate any more than it does now.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
The Following User Says Thank You to hardwareman For This Useful Post:
oh'mike (12-05-2011)
Old 12-04-2011, 11:21 PM   #5
Registered User
Rewards Points: 4,924
I built one with plywood/2x2's for our dryer about 35 years ago--- it still works. No drawer though, those came out later....
Use p.t. wood if an outdoor application?
Gary
Old 12-05-2011, 07:56 AM   #6
Rewards Points: 123
I'm 6'1". Have GE front load washer/dryer set with pedestals. My wife is 5'5" and thinks the washer/dryer without pedestals are too low to the ground. The pedestals are solidly bolted to the appliances, making them single solid units. The dryer is pretty low impact. It just spins quietly. The washer with warp drive spin needs to be carefully leveled so it doesn't rock. It has an out of balance sensor, but if you give it any room to move by not getting equal load on all four feet, it will start dancing.
mwpiper is offline   Reply With Quote
Old 12-07-2011, 12:09 AM   #7
That's what worries me. Almost better to stay on the floor.
Old 12-31-2011, 01:59 AM   #8
I think it's a good idea... it will definitely save your back over time!
I actually spent a full day building one out of various materials, but wood primarly. I did it for two reasons, my units will stack and fit in a custom cabinet and I needed to install an overflow pan with drain. I'm on the second floor of a condo... I have to take precautions. It took me a whole day and then some to make sure the platform would hold a car, lol! You would be amazed at how vibrating objects can destroy things over time!!
GL,
James
jawadesign is offline   Reply With Quote
Flatscreen over the fireplace? Is this really a good idea? kashimama Home Theater 43 11-20-2011 12:01 AM
Thinking of relocating Basement return, good idea? Windwalker HVAC 0 12-19-2010 12:49 PM
Sponging Wet sheetrock mud? Good Idea or No? Scotsman General DIY Discussions 5 11-10-2009 03:14 PM
Is using Luan to overlay soffit a good idea? ConstantChange Roofing/Siding 17 10-19-2009 09:48 AM
Washer/Dryer Pedestal Weight Bearing roystreet Appliances 2 09-08-2009 03:01 PM
