Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 02-28-2009, 05:29 PM   #1
Default Washer Drain line extention
"We have a front load washer and dryer. They presently sit side by side in the laundry room. The washer is on the right and the dryer on the left. The doors open opposite of each other and reversing the doors is not an option. The question is this. Could I switch the locations of the units? The vent for the dryer is not an issue as I have access to the vent in the basement. What is of issue is the drain line for the washer. It is a wall mount on the wall adjacent to the present location of the washer. I estimate the distance from the connection point on the washer to the wall drain to be increased by 36 to 40 inches should we reverse the locations. Question; One, can the pump in the washer accommodate the increase in distance and two, should I extend the hose by adding the necessary length or are there longer hoses available?
Thank you in advance for your help,
Born In America is offline   Reply With Quote
Old 02-28-2009, 05:55 PM   #2
you can extend the hose with no problems. These units are reversed from standard so do move them.
Tags
drains, washer
More On This Topic
We are standing in a room that used to be a carport when the house was originally built and somewhere along the line one of the owners has turned this in to a living quarters, whether it be a bedroom or a family room or whatever and we are in the process... Read More »
Bathroom Design Ideas
Bathroom Design Ideas by Expert Village
When I met with the homeowner he told me where he wanted to build his new bathroom and what he wanted to have in it and where he wanted to have it. Originally he wanted the toilet where I am standing and I told him I thought it would be better in the... Read More »
Black jeans look great when they are brand new, but they tend to fade quickly, becoming a washed out gray color. If you would like to prevent or even reverse the color fading of your favorite black jeans, a few tips can help you to keep them looking like... Read More »
We're going to try first, to pull their existing duct work. I've checked with all the mechanicals, it looks like this air conditioning system can carry the load, of this extra square footage. We're going to try that first, if we need to then supplement... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Whirlpool Duet front loading washer drain pump Jrr1099 Appliances 1 04-08-2009 03:57 PM
Sewer Drain Issues allenzachary Plumbing 20 03-03-2009 09:09 PM
Washer Drain Help Needed PatDaddy Plumbing 4 05-06-2008 12:35 AM
Washer drain peloncito Appliances 7 08-04-2007 02:56 AM
Need to move a tub drain to line up with a new tub, is it ok to do this... *PICS* J187 Plumbing 6 05-23-2006 01:13 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
