Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 12-02-2011, 06:43 AM   #1
Washer drain hose height?
I have a T at about 4 feet hight. Is a washer going to be able to pump the water out with no help?
yuriy128 is offline   Reply With Quote
Old 12-02-2011, 08:31 AM   #2
Ironlight's Avatar
Yes it will.
Ironlight is offline   Reply With Quote
Old 12-02-2011, 10:51 AM   #3
"T" ?.. if you connect it with no air gap you'll have siphon prob. needs check valve.
Jacques is offline   Reply With Quote
Old 12-02-2011, 11:17 AM   #4
sorry, what do u mean by air gap? i dont think i need a separate trap for this, attached is the connection i have( one on the right) Is it ok?
Thanks!
Old 12-02-2011, 06:22 PM   #5
#1 HAWKEYE FAN
hardwareman's Avatar
that is not a T so yest it will be fine
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
washer drain line jbarkley Plumbing 2 05-07-2011 09:52 PM
Unusual washing machine drain hose hook-up gnguru Plumbing 8 04-28-2011 09:40 PM
Problem with Washer drain StephenM Plumbing 1 04-01-2011 06:37 PM
Looking for Washer drain solution RobertSch Plumbing 5 01-28-2009 10:08 AM
Fleible drain hose for shower? devouru Plumbing 1 06-25-2008 11:06 AM
