Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Appliances
Old 01-07-2012, 06:05 PM   #1
Washer Drain Hose
Took an old Roper washer to the hunting cabin ( way out in the woods ) and set it up by laying the drain hose on the ground. Turned it on and the tub will not fill, water went out the drain hose. Is the washer broken or do I need to rig up a standpipe ? I think I need a standpipe but want to make sure. Thanks in advance.
Rocksprings is offline   Reply With Quote
Old 01-07-2012, 06:07 PM   #2
Washer Drain Hose
Stand pipe needs to be above the top of the washer.
Rocksprings (01-07-2012)
Old 01-07-2012, 06:12 PM   #3
Washer Drain Hose
yes hose needs to be in a stand pipe or above rim of washer to operate right...
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 01-07-2012, 06:16 PM   #4
Washer Drain Hose
Just attaching it to the back of the washing machine with a wire will work.
Old 01-07-2012, 09:45 PM   #5
Washer Drain Hose
One more stupid question, Do I need an elbow (trap) on the bottom of the standpipe keeping in mine it will drain on the ground ? I am thinking the trap is only used to keep the gas and smell out of the room when connected in a house.
Old 01-07-2012, 10:42 PM   #6
Washer Drain Hose
you are right don't need a trap if just draining to the ground...traps are only for sewer gas....
Old 01-08-2012, 09:00 AM   #7
Washer Drain Hose
To prevent overloading the washing machine pump and also to prevent siphoning of the wash tub contents during the wash portion of the cycle, the end of the drain hose must be above the wash tub rim and not sealed or spliced to anything.
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
The Following User Says Thank You to AllanJ For This Useful Post:
Rocksprings (01-08-2012)
Old 01-08-2012, 09:58 AM   #8
Washer Drain Hose
They make a syphon breaker that should go into the hose that stick's in the stand pipe or get the hose as high as the tube to prevent syphon of water . this makes a air breake in the line. this is a T the line goes on the long end and the drain goes on the other long end the side piece is the air inlet .
del schisler is offline   Reply With Quote
The Following User Says Thank You to del schisler For This Useful Post:
Old 01-09-2012, 08:20 AM   #9
Washer Drain Hose
Your neighbors well water tasting a little off?
Jacques is offline   Reply With Quote
Old 01-09-2012, 09:06 AM   #10
Washer Drain Hose
My well and neighbors are 450 ft deep (solid rock) We take water any way we can get it here in South West Texas. Still have an outhouse also . Water is excellent.
Unusual washing machine drain hose hook-up gnguru Plumbing 8 04-28-2011 09:40 PM
tie in washer drain to toilet? markallan Plumbing 0 02-22-2011 08:40 PM
overflowing washer drain pipe? mcasso Plumbing 2 07-26-2010 08:13 PM
relocating washer drain idodishez Plumbing 7 04-21-2009 09:36 PM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
