Washer Drain Above Machine - Appliances - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 07:57 PM   #1
Rewards Points: 150
Washer drain above machine
Hi, my sewer line is 6 feet above the floor in my basement. I do NOT have a basement drain. Is the washing machine pump strong enough to move the water UP to the sewer line? I do not have the space for a first floor laundry.
Cossack is offline   Reply With Quote
Old 06-09-2012, 08:04 PM   #2
DIY staff
Rewards Points: 7,174
Not going to work---
You will need a sewage pit or a sewage ejector box---
Old 06-09-2012, 09:36 PM   #3
Rewards Points: 254
If it's just for the washing machine how about draining into a deep utility sink and a sump pump to the sewer line.
cjm94 is offline   Reply With Quote
Old 06-09-2012, 09:45 PM   #4
Rewards Points: 150
Would the utility sink drian into a sump pit? I would have to buy another sump pump. Aren't there smaller less expensive pumps for this job? I was hoping the washing machine would have enough power to get the water up 5 feet or so. Could I put the washing machine on a block to make it closer?
Old 06-09-2012, 10:04 PM   #5
Rewards Points: 254
I had a washing machine drain that was level with the top of the machine with no problems not sure how high it can pump though.
I was thinking a small sump in the sink if the washer pump isn't strong enough.
Old 06-09-2012, 10:26 PM   #6
DIY staff
Call your local plumbing supply house----the is a 'sump box'---like an on the floor sump pit/pump designed for just what you need to do---cheaper than digging a pit--and little work to install---
Old 06-10-2012, 02:24 PM   #7
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
most washers can pump to that hieght, as long as it is not a front loader you should be ok.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 06-10-2012, 02:47 PM   #8
Rewards Points: 6,652
For the two houses that I grew up in, that the sewer line was about that high, we never had a problem with draining the wash machine . You would be surprised how far a wash machine pump can shoot water and the force it does it at.
Old 06-10-2012, 07:41 PM   #9
Rewards Points: 150
Thankd hardwareman and gegzoll. I always like the least expensive alternatives.
Old 06-11-2012, 07:38 AM   #10
Rewards Points: 1,512
So long as the drain hose that came with the machine can reach up to the drain pipe and fit loosely then it will work okay.
You may not splice more length onto the hose except as allowed by the machineinstructions; that could overload the machine's internal pump.
By the way, drain openings low to the floor can also present a challenge. The drain hose must loop up above the highest level in the rotating tub/drum the wash water could ever attain during a wash cycle and then reach down to the drain opening. This is to prevent premature loss of the wash water during the cycle.
Washing Machine Drain handy man88 Plumbing 17 12-23-2012 07:16 AM
Washer Drain Overflows ryanb4614 Plumbing 2 03-20-2012 11:12 PM
Septic odor from washer machine drain TMC Plumbing 4 02-02-2012 07:40 PM
tie in washer drain to toilet? markallan Plumbing 0 02-22-2011 07:40 PM
Washing Machine Drain Pipe overflows evol200 Plumbing 3 01-27-2011 12:41 PM
