Washer Busted? - Appliances - DIY Chatroom Home Improvement Forum
Old 01-18-2013, 02:00 PM   #1
Home Performance
HomeSealed's Avatar
Rewards Points: 712
washer busted?
So I'm not an appliance guy, and I'm looking for some input before I start tearing this thing apart...
I have an approx 15yr old maytag front load washer. Came downstairs before (washer had been in the middle of a cycle), and there is soapy water all over the floor, the washer is doing nothing but buzzing, and it smells like band-aids.
Opened it up and it spins freely inside, but it does nothing when I try to turn it back on but buzz.
I'm thinking the motor is shot? Thoughts?
Secondly, if that is the case (or something else), is it even worth repairing?
Thanks in advance for input
Replacement Windows, doors, siding, roofing, insulation, and BPI certified energy consulting, Building Analyst 5051322
www.HomeSealed.com
Replacement Windows Milwaukee
HomeSealed is offline   Reply With Quote
Old 01-18-2013, 02:48 PM   #2
Rewards Points: 13,300
Now you know someones going to need the make and model #.
If it's 15 years old I would not be spending a whole lot of money on it.
Old 01-18-2013, 02:54 PM   #3
Home Performance
HomeSealed's Avatar
Rewards Points: 712
maytag neptune mah5500bww
... that was my thought as well, but I don't want to trash it if there is a cheap fix
www.HomeSealed.com
Old 01-18-2013, 05:06 PM   #4
Motor buzzing doesn't jive with soapy water discharge. More likely a busted water discharge pump. At 15 though, it may not be worth it. I had a washer that long that went through two motor shaft couplings until they were obsolete wo replacement. It's worth pulling apart to see at least.
64pvolvo1800 is offline   Reply With Quote
Old 01-18-2013, 05:12 PM   #5
Give this a shot.
http://www.repairclinic.com/RepairHe...roubleshooting
Old 01-18-2013, 08:46 PM   #6
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,600
just take the front and back panel off. Take a look around in there, maybe as simple as the drive belt. I would spend a few bucks to repair that machine before I would buy new.
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 01-21-2013, 04:20 PM   #7
Home Performance
HomeSealed's Avatar
Rewards Points: 712
Someone elses problem now. Got a new set delivered over the weekend.
www.HomeSealed.com
Under counter washer / dryer installation wstt Plumbing 0 04-10-2012 12:00 PM
bolt that holds the tank to the toilet bowl is leaking andrewjs18 Plumbing 13 04-06-2012 11:43 AM
Washer & Dryer Holiday Fun BRIANisMEisWE Appliances 8 12-24-2011 03:41 AM
MayTag Neptune washer leaking door Ufers5 Appliances 4 12-06-2010 02:01 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 03:15 PM
