Wall Oven Temp Off By 40-50 Degrees - Appliances - DIY Chatroom Home Improvement Forum
Old 12-02-2011, 11:01 AM   #1
I can do it......I think!
Send a message via Yahoo to MovedTooMuch
Wall oven temp off by 40-50 degrees
I have a Frigidaire wall oven (FEB24S5ASB). i noticed that foods took longer to cook than before. When I added a thermometer inside I noticed it was 40-50 degrees off (cooler) than the digital display. I replaced the temperature sensor ($28) and I am still getting the same result.
The only thing left seems to be the bake burner element but that appears to be in good shape. A physical inspection reveals no issues or damage. It also glows orange for 90% of the length (except ends near the wall which I think is normal). The bake element is $85. I don't want to just keep swapping parts. Any suggestions?
MovedTooMuch is offline   Reply With Quote
Old 12-02-2011, 06:29 PM   #2
#1 HAWKEYE FAN
hardwareman's Avatar
Rewards Points: 1,588
don't waste your money on a new bake element, if it glows it is good. Sounds like your going to need a new erc (electronic range control)
................."I want a house that has gotten over all its troubles. I dont' want to spend the rest of life bringing up a young and inexperienced house"...........
hardwareman is offline   Reply With Quote
Old 12-02-2011, 06:49 PM   #3
Thanks for the reply. Would that be the same as the Controller or the Control Panel?
I don't see electronic range control on the appliance parts websites.
Old 12-02-2011, 08:26 PM   #4
Pro Slate Roofer
tinner666's Avatar
Rewards Points: 1,060
Until you get it figured out, set your temp 45 degrees above what's called for.
Ovens with a dial set are fully adjustable for that with a set screw on the back of the dial. I've never tried anything on one with a gigital display.
I tried to get an answer here, but I think I screwed up. http://www.helpowl.com/p/Frigidaire/...%20wall%20oven
The manual is here---http://www.manualowl.com/p/Frigidaire/FEB24S5AS/Manual/96018
tinner666 is offline   Reply With Quote
Old 12-02-2011, 11:37 PM   #5
#1 HAWKEYE FAN
yes, control panel
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 03:19 PM
Retaining Wall and Muddy Yard rjschwar Landscaping & Lawn Care 10 02-24-2010 01:55 PM
Wall Oven Depth Surprise carusob Carpentry 2 06-29-2009 08:57 AM
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 1 03-11-2009 05:48 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
