-   -   Wall oven temp off by 40-50 degrees (http://www.diychatroom.com/f47/wall-oven-temp-off-40-50-degrees-125320/)
MovedTooMuch 12-02-2011 11:01 AM
I have a Frigidaire wall oven (FEB24S5ASB). i noticed that foods took longer to cook than before. When I added a thermometer inside I noticed it was 40-50 degrees off (cooler) than the digital display. I replaced the temperature sensor ($28) and I am still getting the same result.
The only thing left seems to be the bake burner element but that appears to be in good shape. A physical inspection reveals no issues or damage. It also glows orange for 90% of the length (except ends near the wall which I think is normal). The bake element is $85. I don't want to just keep swapping parts. Any suggestions?
hardwareman 12-02-2011 06:29 PM
don't waste your money on a new bake element, if it glows it is good. Sounds like your going to need a new erc (electronic range control)
MovedTooMuch 12-02-2011 06:49 PM
Thanks for the reply. Would that be the same as the Controller or the Control Panel?
I don't see electronic range control on the appliance parts websites.
tinner666 12-02-2011 08:26 PM
Until you get it figured out, set your temp 45 degrees above what's called for.
Ovens with a dial set are fully adjustable for that with a set screw on the back of the dial. I've never tried anything on one with a gigital display.
I tried to get an answer here, but I think I screwed up. http://www.helpowl.com/p/Frigidaire/...%20wall%20oven
The manual is here---http://www.manualowl.com/p/Frigidaire/FEB24S5AS/Manual/96018
hardwareman 12-02-2011 11:37 PM
yes, control panel
