Wall Oven - Appliances - DIY Chatroom Home Improvement Forum
Old 11-02-2010, 06:05 PM   #1
wall oven
the depth of my wall is 23", so the oven has to be less than that. I can't find one. Can you help me?
lindalaval is offline   Reply With Quote
Old 11-02-2010, 09:41 PM   #2
HVAC / Plumbing
Must be an older unit. If you can't find 1 to match. You'll have to make adjustments. That's just the way it is when you replace older appliances with new. nothing will fit. I have had to cut holes larger many times for newer appliances to fit
kenmac is offline   Reply With Quote
Wall - LOAD BEARING: How to Move? user49172 Building & Construction 6 05-19-2017 04:53 PM
New wall oven has 4 wires wall has three hobiecatman Electrical 5 10-05-2010 06:19 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 10:32 AM
Kenmore Wall Oven doesn't turn on queen614621 Appliances 1 12-15-2008 04:45 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
